Dutch 230 SL Pagode 1965 restoration project
Dieses Thema im Forum "Bildergalerie" wurde erstellt von EeVeeWee, 28. September 2018.
  1. EeVeeWee
    EeVeeWee Aktives Mitglied
    217
    21. September 2018
    The assembly of the front suspension is going well.
    Nice to see the difference with how it was!
    9h11e gefällt das.
  2. EeVeeWee
    217
    21. September 2018
    The rear axle is completely disassembled.
    Fortunately all bearings, bushings and crown and pinion wheel are in a good shape.
    In the meanwhile some nice new parts for the front suspension have been delivered.
    coca-light und 9h11e gefällt das.
  3. EeVeeWee
    217
    21. September 2018
    Today I picked up the Pagode at the blaster.
    It looks like a completely other car in the zinc epoxy color!
    coca-light, Cephyr und 9h11e gefällt das.
  4. EeVeeWee
    217
    21. September 2018
    Nice to see all the original spot weldings, now the bottom is blasted.
    Fortunately no nasty surprises, just some little holes to repair.
  5. EeVeeWee
    217
    21. September 2018
    At the and of this year I still repaired some small holes in the bottom.
    The next step will be replacing a part of the floor.
    coca-light gefällt das.
  6. EeVeeWee
    217
    21. September 2018
    The new part of the floor is already welded in place.
  7. Sinan
    xxxxxxx
    230sl64 gefällt das.
  8. EeVeeWee
    217
    21. September 2018
    I renewed a piece of the rear fender.
  9. EeVeeWee
    217
    21. September 2018
    The housing of the LH headlight was bad, but now it is restored.
    The trick is now to keep this place in the front fender free form dirt.
  10. EeVeeWee
    217
    21. September 2018
    This bad spot is also repaired.
  11. EeVeeWee
    217
    21. September 2018
    Also the bottom of LH side rear fender has been renewed.
  12. EeVeeWee
    217
    21. September 2018
    Another bad spot repaired.
  13. M127II
    Eric,
    Looking good, very fine work:):)
    BTW, did you fabricate that repair section for the lower front fender section yourself or was it a prefabricated one?:2cent:
    You are working fast. Love to see your progress.
    Keep on the good work.
    Best,
    9h11e gefällt das.
  14. EeVeeWee
    217
    21. September 2018
    Hi Achim,
    Thank you.
    I used a part of a patch panel, like on the picture:
  15. EeVeeWee
    217
    21. September 2018
    There was a bad repaired spot at the back which was also slightly bent inwards, compared to the straight green line.
    So also here I welded a part of the back section.
    suederbravo und 9h11e gefällt das.
  16. EeVeeWee
    217
    21. September 2018
    Smearing with 3M body sealer.
    9h11e gefällt das.
  17. EeVeeWee
    217
    21. September 2018
    This is not because it's cold in the garage.
    It could have been art, but it's not.
    It's just protection against 3M™ Body Gard which is going to be sprayed against the bottom. ;D
  18. ursodent
    A kind of bonding??
    :cool::D
  19. EeVeeWee
    217
    21. September 2018
    A late Christmas present. :)
  20. rolf230
    rolf230 Aktives Mitglied
    670
    2. Oktober 2008
    God Job. A new "Christo" is born :tanzen:
    Günnipagode gefällt das.
