Dutch 230 SL Pagode 1965 restoration project
- Ersteller EeVeeWee
- Erstellt am
EeVeeWee
- 21. September 2018
I found an original tow bar mounting beam, I just have to drill some mounting holes and weld some spacers.
At the second picture it is clear to see that the last owner had some terrible grit blasting been done.
The dents were filled with bondo and also the bonnet is like this.
So these aluminum parts must be made in the right curve again.
Unfortunately not every sheet metal worker has that skills.
Mrs. Candler
- 16. Januar 2018
Goedendag!
Was kostet ein guter gebrauchter Heckdeckel samt Anpassungsarbeiten?
Vermutlich weniger als die Richtung dieses Meisterstückes, oder?
What´s the price of an used trunk lid in good shape - incl. some bodywork for adjustment?
Less high than fixing this lttle piece of art I guess.
Mein Beileid / my deepest condolences
Remco
Remco
schlüssellos
- 4. Februar 2009
ich habe noch nie gesehen, dass das innere Verstärkungskreuz durch den Deckel zu sehen ist, wie hier.
Was ist denn da passiert?
EeVeeWee
What ...?
Eric...?
Are all these dark (appearing) areas on your trunk lid dents??
Unbelievable, that's terrible.
Have you already talked about this to a good dent doctor?
Best,
Hi Achim,
Yes unfortunately the complete upper part is bent.
I have found someone who is able to repair this, but it will take some hours.
EeVeeWee
Probably the previous owner had the tailgate been blasted with sand or grit.
This causes too much strength and warmth. Then flattened with bondo.
M127II
M127II
- 21. April 2007
Wow ... Eric,
You'r really fast !
Don'Tt you have a daytime job to do?
Or have you already done all the work presented above (and even much more) long ago in the past and only present the ongoing process here now one after the other?
Anyway,
very, very well done!
Keep on the excellent work!
You'r really fast !
Anyway,
EeVeeWee
I have a full time job (4 times 9 hours a week), but I'm free at Wednesday for the restoration.
Also at Tuesday evening, Thursday evening and Sunday afternoon I'm working on it.
So at this moment, the 5 months I have this 230 SL, there are already 300 hours used, including the help from others.
MartinK
schraubt hemdsärmelig
- 19. Mai 2012
Hei, EeVeeWee
Please delete the picture with the spring tensioner. This tool is highly dangerous and could cost your life. Nobody should see and copy this. Your other work is nice to see. Talk soon, take care and throw those tensioner to the junkyard. Martin
https://forum.mercedesclub.de/index.php/Thread/14153-Falsche-Federspanner-sind-gefährlich/
EeVeeWee
Hei, EeVeeWee
Which one is not safe according you?
This one:
Or this one:
EeVeeWee
The brake adjusting plates had to be fixed at the pins again.
I made a tool to press the spring together with the plate in position.
After welding I grinded off the excess material.
And finally put this side in the paint.
